Rappel à venir
Re: Rappel à venir
"Buy the rumor, sell the News" (Charles DOW)
Le victoire de Macron et de sa clique est une continuité - normal qu'il n'y ait pas d'impact
J'entends encore un copain en train de me dire " vote macron, c'est super, rien ne va changer"
Quand au brexit, les marchés ne s'y sont pas trompés car dans le curseur des analystes financiers (fondamentaux) c'est une bonne chose ;-)
Tiens à ce sujet, j'ai entendu à la radio cet après midi qu'un groupe automobile anglais prévoyait 5000 embauches en angleterre en 2018
Gooooood :)
Re: Rappel à venir
Rappel sur V8V boite SS 2011-2014
2017-06-22 (Published by NHTSA on 2017-07-01) Recall Summary: Aston Martin the Americas (Aston Martin) is recalling certain 2011-2014 V8 Vantage vehicles equipped with 7-speed Auto-Shift Manual (ASM) "SportShift II" transmissions. A connector for the clutch fluid line may break, resulting in a hydraulic fluid leak. Hazard: The loss of hydraulic fluid may prevent the vehicle from shifting out of the gear that it is in. Additionally, if the vehicle is being driven when the fluid level significantly drops, the transmission may shift to an emergency neutral as the vehicle comes to a stop. If the driver ignores the dash warning message and exits the vehicle without applying the parking brake, the vehicle may roll away. Either condition increases the risk of a crash. Remedy: Aston Martin will notify owners, and dealers will install a support bracket to hold pipe securely in position, free of charge. The recall is expected to begin July 7, 2017. Owners may contact Aston Martin customer service at 1-949-379-3100. Aston Martin's number for this recall is RA-07-0024. Additional Info: Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov. NHTSA Source: http://www-odi.nhtsa.dot.gov/recalls/recallresults.cfm?start=1&SearchType=QuickSearch&rcl_ID=17V391000 2017-06-21 (Published by NHTSA on 2017-06-28) Recall Summary: Aston Martin Lagonda of North America (Aston Martin) is recalling certain 2011-2012 V8 Vantage vehicles. The affected vehicles received updated transmission and engine control software which may conflict with the pre-existing clutch settings causing the transmission to act like it has been shifted to neutral. Hazard: A transmission that does not operate as intended can increase the risk of a crash. Remedy: Aston Martin will notify owners, and dealers will reinstall clutch system software, free of charge. The recall is expected to begin July 7, 2017. Owners may contact Aston Martin customer service at 1-866-278-6661. Aston Martin's number for this recall is RA-07-0022. Additional Info: Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov. NHTSA Source: http://www-odi.nhtsa.dot.gov/recalls/recallresults.cfm?start=1&SearchType=QuickSearch&rcl_ID=17V389000
Bacchus83
Véhicule : Vantage V12S
Re: Rappel à venir
Message par Bacchus83 »
Toujours bon à savoir. Merci pour l'info (y)
